Q: In Futures web page/App, you can check “TP/SL” box to place a limit/market order followed by a TP order and/or an SL order. Is there an API interface to do that?
A:
There’s no direct way to do it but you can leverage on WSS and code logic to get similar effect. Below is the procedure:
- Listen to your futures user data stream - https://binance-docs.github.io/apidocs/futures/en/#user-data-streams
- Place the limit/market order as you planned and specify a unique client order id to identify it later
- If you receive an event from your user data stream indicating that particular order has been filled, place the TP/SL order(s) with unique client order ID. The orders both should be reduce-only and same quantity as your order placed in #2
- Keep tracking your TP/SL orders(s) until either one of your TP/SL orders gets filled (it would go through triggering stage and then get filled)
- Cancel the other order (might have been triggered and turned to a limit order)
Hey, I am unable to set up a scenario like you described, for my take profit/stoploss orders I keep receiving “-1106: Parameter ‘reduceOnly’ sent when not required.”
Settings I used for testing:
symbol = btcusdt
signal = Signal.BUY; (Buy market order with sell for stoploss/take profit)
quantity = 0.01
takeprofit = 59000
stoploss = 58000
I fetch their unique client order IDs from the result, instead of generating my own as it seemed easier.
I first create a market order, which works fine (the order appears on the testnet platform)
And then create the 2 stoploss/take profit orders (but both of them respond with the same error)
like this:
Order marketOrder = syncRequestClient.postOrder(
symbol,
side == Signal.SELL ? OrderSide.SELL : OrderSide.BUY,
side == Signal.SELL ? PositionSide.SHORT : PositionSide.LONG,
OrderType.MARKET,
null, //TimeInForce
quantity.toString(), //Quantity
null, //Price
null, //Reduce only
null, //NewClientOrderId
null, //Stop price
null, //workingType
NewOrderRespType.RESULT //NewOrderRespType
Order stopOrder = syncRequestClient.postOrder(
symbol,
side == Signal.SELL ? OrderSide.BUY : OrderSide.SELL,
OrderType.LIMIT,
TimeInForce.GTC,
stoploss.toString(),
"true", //Reduce only
null, //Stop price
null, //workingType
Order profitOrder = syncRequestClient.postOrder(
symbol,
OrderType.LIMIT,
TimeInForce.GTC,
null, //takeprofit.toString(), //Price
takeprofit.toString(), //Stop price
null, //workingType
I’ve tried using the stop price instead of price, and also in one-way mode but it I can not get it to work
This is a knowledge sharing topic. Please open your problem with a new one
