Binance Testnet links
Spot Testnet:
https://testnet.binance.vision/
Futures Testnet:
https://testnet.binancefuture.com
See instructions below on how to open a testnet account for both SPOT and FUTURES.
Q: How do I create an API key for the SPOT Testnet?
A: From https://testnet.binance.vision/, you can see this link to login
Once your account has been authenticated, you will be redirected back to testnet page and there will be another link to generate the API key
Click the button and give a label to your API key in the next screen, then you will see the API key:
Don’t forget to Save the secret key as it won’t be shown again.
Q: How do I open a testnet account and generate a testnet API key for Futures?
A: From https://testnet.binancefuture.com, find the “Register now” button from the bottom of the page, underneath the kline chart:
After click there, you will be asked to provide email address and password to generate a testnet account.
This account is separate with your production account, It’s recommended to use a different email and password.
After login with the testnet username and password, you will see the tab of “API Key” with API Key and secret:
There will be some funds already in the account, and this cannot be withdrawn.
