I sometimes get following error in margin trading;
Error Code: -3013
Message: Borrow amount less than minimum borrow amount
How can i learn the min. amount that i can borrow? So that i can avoid from this error…
Error Code: -3013
It’s mentioned in the docs
GET /sapi/v1/margin/asset
"assetFullName": "Binance Coin",
"assetName": "BNB",
"isBorrowable": false,
"isMortgageable": true,
"userMinBorrow": "0.00000000",
"userMinRepay": "0.00000000"
The above request has a weight of 10, but you could fetch all assets instead and that will have a weight of 1:
GET /sapi/v1/margin/allAssets
"assetFullName": "USD coin",
"assetName": "USDC",
"isBorrowable": true,
Thank you
One more question @tftd ;
GET /sapi/v1/margin/allAssets return total of 163 assets information. But Binance has 292 assets that you can trade isolated margin ( with usdt quote asset).
What about the remaining (296-163 = 133 assets) MinBorrow information? For example BADGERUSDT, HIGHUSDT , CVPUSDT , SCRTUSDT…
BADGER, HIGH, CVP , SCRT… are not included in GET /sapi/v1/margin/allAssets return data. Where can learn the min borrow quantity for these assets?
Thank you.
Unfortunately I don’t do margin trading so I don’t know the answer to your question. Maybe create a new thread and some of the devs / support will answer it.
Not all assets on Binance can be traded on margin, as you mention 292 assets can be traded on spot but of those only 163 can be traded on margin
292 is the number of assets that you can isolated margin trade.
Spot Trading is available on more than 339 assets throught USDT quote asset.
