About Websocket limitations per second
I need to subscribe to the ‘USER_DATA’ stream for each of the 2000 accounts individually using the ‘binance-futures-connector-python’ (official framework) because I will be frequently closing some sockets and adding new ones in their place (unsubscribe > new listen key > subscribe).
I have seen that the websocket has a limit of 5 messages per second:
Are these messages counted separately for each subscription?
In other words, do I have a limit of 5 messages per second for each ‘Listen Key’ that is subscribed to separately with 'id':1, 'id':2, .. 'id':2000? Or do I have a limit of 5 messages per second for all 2000 subscribers?
If it is for all of them, it seems that I will exceed the limit of 5 messages per second several times a day. Is there a way to prevent this?
Update:
Streams are seems stable with 13 users (using more than 5 message/sec with pongs) but still don’t know if my IP or something will get banned
2022-12-14 16:38:49,217 - script - INFO - Websocket is connected
2022-12-14 16:38:49,899 - script - INFO - # Fetch Listen Key # | User: user-4  | Listen Key: key-4  | Status: Success!
2022-12-14 16:38:49,918 - script - INFO - # Fetch Listen Key # | User: user-5  | Listen Key: key-5  | Status: Success!
2022-12-14 16:38:49,919 - script - INFO - # Fetch Listen Key # | User: user-2  | Listen Key: key-2  | Status: Success!
2022-12-14 16:38:49,921 - script - INFO - # Fetch Listen Key # | User: user-9  | Listen Key: key-9  | Status: Success!
2022-12-14 16:38:49,923 - script - INFO - # Fetch Listen Key # | User: user-6  | Listen Key: key-6  | Status: Success!
2022-12-14 16:38:49,930 - script - INFO - # Fetch Listen Key # | User: user-10 | Listen Key: key-10 | Status: Success!
2022-12-14 16:38:49,950 - script - INFO - # Fetch Listen Key # | User: user-3  | Listen Key: key-3  | Status: Success!
2022-12-14 16:38:49,967 - script - INFO - # Fetch Listen Key # | User: user-11 | Listen Key: key-11 | Status: Success!
2022-12-14 16:38:49,969 - script - INFO - # Fetch Listen Key # | User: user-13 | Listen Key: key-13 | Status: Success!
2022-12-14 16:38:49,977 - script - INFO - # Fetch Listen Key # | User: user-12 | Listen Key: key-12 | Status: Success!
2022-12-14 16:38:49,992 - script - INFO - # Fetch Listen Key # | User: user-1  | Listen Key: key-1  | Status: Success!
2022-12-14 16:38:50,539 - script - INFO - # Fetch Listen Key # | User: user-7  | Listen Key: key-7  | Status: Success!
2022-12-14 16:38:50,555 - script - INFO - # Fetch Listen Key # | User: user-8  | Listen Key: key-8  | Status: Success!
2022-12-14 16:38:50,560 - root - INFO - Connection with URL: wss://stream.binancefuture.com//ws
2022-12-14 16:38:50,561 - script - INFO - User data stream is sent
2022-12-14 16:38:50,561 - root - INFO - Connection with URL: wss://stream.binancefuture.com//ws
2022-12-14 16:38:50,562 - root - INFO - Connection with URL: wss://stream.binancefuture.com//ws
2022-12-14 16:38:50,562 - script - INFO - User data stream is sent
2022-12-14 16:38:50,563 - script - INFO - User data stream is sent
2022-12-14 16:38:50,563 - root - INFO - Connection with URL: wss://stream.binancefuture.com//ws
2022-12-14 16:38:50,564 - root - INFO - Connection with URL: wss://stream.binancefuture.com//ws
2022-12-14 16:38:50,564 - script - INFO - User data stream is sent
2022-12-14 16:38:50,565 - root - INFO - Connection with URL: wss://stream.binancefuture.com//ws
2022-12-14 16:38:50,565 - script - INFO - User data stream is sent
2022-12-14 16:38:50,566 - script - INFO - User data stream is sent
2022-12-14 16:38:50,566 - root - INFO - Connection with URL: wss://stream.binancefuture.com//ws
2022-12-14 16:38:50,864 - root - INFO - Start to connect....
2022-12-14 16:38:51,163 - root - INFO - Start to connect....
2022-12-14 16:38:51,460 - root - INFO - Start to connect....
2022-12-14 16:38:51,752 - root - INFO - Start to connect....
2022-12-14 16:38:52,037 - root - INFO - Start to connect....
2022-12-14 16:38:52,330 - root - INFO - Start to connect....
2022-12-14 16:38:52,615 - root - INFO - Start to connect....
2022-12-14 16:38:52,900 - root - INFO - Start to connect....
2022-12-14 16:38:53,186 - root - INFO - Start to connect....
2022-12-14 16:38:53,477 - root - INFO - Start to connect....
2022-12-14 16:38:53,763 - root - INFO - Start to connect....
2022-12-14 16:38:54,049 - root - INFO - Start to connect....
2022-12-14 16:38:54,338 - root - INFO - Start to connect....
2022-12-14 16:38:55,547 - root - INFO - Server connected
2022-12-14 16:38:55,548 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-12"], "id": 10}'
2022-12-14 16:38:55,554 - root - INFO - Server connected
2022-12-14 16:38:55,554 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-5"], "id": 3}'
2022-12-14 16:38:55,555 - root - INFO - Server connected
2022-12-14 16:38:55,555 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-3"], "id": 8}'
2022-12-14 16:38:55,556 - root - INFO - Server connected
2022-12-14 16:38:55,556 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-4"], "id": 5}'
2022-12-14 16:38:55,557 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-1"], "id": 11}'
2022-12-14 16:38:55,557 - root - INFO - Server connected
2022-12-14 16:38:55,558 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-13"], "id": 1}'
2022-12-14 16:38:55,565 - root - INFO - Server connected
2022-12-14 16:38:55,565 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-8"], "id": 13}'
2022-12-14 16:38:55,602 - root - INFO - Server connected
2022-12-14 16:38:55,603 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-6"], "id": 4}'
2022-12-14 16:38:55,605 - root - INFO - Server connected
2022-12-14 16:38:55,606 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-9"], "id": 6}'
2022-12-14 16:38:55,606 - root - INFO - Server connected
2022-12-14 16:38:55,607 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-11"], "id": 9}'
2022-12-14 16:38:55,607 - root - INFO - Server connected
2022-12-14 16:38:55,608 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-10"], "id": 7}'
2022-12-14 16:38:55,608 - root - INFO - Server connected
2022-12-14 16:38:55,608 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-7"], "id": 12}'
2022-12-14 16:38:55,609 - root - INFO - Server connected
2022-12-14 16:38:55,610 - root - INFO - Sending message to Server: b'{"method": "SUBSCRIBE", "params": ["key-2"], "id": 2}'
MESSAGE WITH ID:  {'id': 11, 'result': None}
MESSAGE WITH ID:  {'id': 8,  'result': None}
MESSAGE WITH ID:  {'id': 5,  'result': None}
MESSAGE WITH ID:  {'id': 13, 'result': None}
MESSAGE WITH ID:  {'id': 3,  'result': None}
MESSAGE WITH ID:  {'id': 4,  'result': None}
MESSAGE WITH ID:  {'id': 10, 'result': None}
MESSAGE WITH ID:  {'id': 1,  'result': None}
MESSAGE WITH ID:  {'id': 6,  'result': None}
MESSAGE WITH ID:  {'id': 9,  'result': None}
MESSAGE WITH ID:  {'id': 7,  'result': None}
MESSAGE WITH ID:  {'id': 12, 'result': None}
MESSAGE WITH ID:  {'id': 2,  'result': None}
2022-12-14 16:39:00,289 - root - INFO - Received Ping from server
2022-12-14 16:39:00,289 - root - INFO - Responded Pong to server
2022-12-14 16:39:00,290 - root - INFO - Received Ping from server
2022-12-14 16:39:00,290 - root - INFO - Responded Pong to server
2022-12-14 16:39:00,291 - root - INFO - Received Ping from server
2022-12-14 16:39:00,291 - root - INFO - Responded Pong to server
2022-12-14 16:39:00,292 - root - INFO - Received Ping from server
2022-12-14 16:39:00,292 - root - INFO - Responded Pong to server
2022-12-14 16:39:00,293 - root - INFO - Received Ping from server
2022-12-14 16:39:00,293 - root - INFO - Responded Pong to server
2022-12-14 16:41:48,414 - root - INFO - Received Ping from server
2022-12-14 16:41:48,415 - root - INFO - Responded Pong to server
2022-12-14 16:41:48,415 - root - INFO - Received Ping from server
2022-12-14 16:41:48,416 - root - INFO - Received Ping from server
2022-12-14 16:41:48,416 - root - INFO - Responded Pong to server
2022-12-14 16:41:48,418 - root - INFO - Received Ping from server
2022-12-14 16:41:48,418 - root - INFO - Responded Pong to server
2022-12-14 16:41:48,420 - root - INFO - Received Ping from server
2022-12-14 16:41:48,420 - root - INFO - Responded Pong to server
2022-12-14 16:43:55,316 - root - INFO - Received Pong from server
2022-12-14 16:43:55,322 - root - INFO - Received Pong from server
2022-12-14 16:43:55,323 - root - INFO - Received Pong from server
2022-12-14 16:43:55,328 - root - INFO - Received Pong from server
2022-12-14 16:43:55,329 - root - INFO - Received Pong from server
2022-12-14 16:43:55,338 - root - INFO - Received Pong from server
2022-12-14 16:43:55,339 - root - INFO - Received Pong from server
2022-12-14 16:44:00,268 - root - INFO - Received Ping from server
2022-12-14 16:44:00,268 - root - INFO - Responded Pong to server
2022-12-14 16:44:00,269 - root - INFO - Received Ping from server
2022-12-14 16:44:00,269 - root - INFO - Responded Pong to server
2022-12-14 16:44:00,270 - root - INFO - Responded Pong to server
2022-12-14 16:44:00,270 - root - INFO - Received Ping from server
2022-12-14 16:44:00,273 - root - INFO - Received Ping from server
2022-12-14 16:44:00,273 - root - INFO - Responded Pong to server
2022-12-14 16:44:00,274 - root - INFO - Responded Pong to server
2022-12-14 16:44:00,274 - root - INFO - Received Ping from server
2022-12-14 16:46:48,424 - root - INFO - Received Ping from server
2022-12-14 16:46:48,425 - root - INFO - Responded Pong to server
2022-12-14 16:46:48,425 - root - INFO - Received Ping from server
2022-12-14 16:46:48,426 - root - INFO - Received Ping from server
2022-12-14 16:46:48,426 - root - INFO - Responded Pong to server
2022-12-14 16:46:48,427 - root - INFO - Responded Pong to server
2022-12-14 16:46:48,427 - root - INFO - Received Ping from server
2022-12-14 16:46:48,428 - root - INFO - Received Ping from server
2022-12-14 16:46:48,428 - root - INFO - Responded Pong to server
2022-12-14 16:48:55,293 - root - INFO - Received Pong from server
2022-12-14 16:48:55,295 - root - INFO - Received Pong from server
2022-12-14 16:48:55,296 - root - INFO - Received Pong from server
2022-12-14 16:48:55,297 - root - INFO - Received Pong from server
2022-12-14 16:48:55,298 - root - INFO - Received Pong from server
2022-12-14 16:48:55,299 - root - INFO - Received Pong from server
2022-12-14 16:48:55,300 - root - INFO - Received Pong from server
2022-12-14 16:48:55,301 - root - INFO - Received Pong from server
2022-12-14 16:48:55,303 - root - INFO - Received Pong from server
2022-12-14 16:48:55,305 - root - INFO - Received Pong from server
2022-12-14 16:49:00,261 - root - INFO - Received Ping from server
2022-12-14 16:49:00,262 - root - INFO - Responded Pong to server
2022-12-14 16:49:00,262 - root - INFO - Received Ping from server
2022-12-14 16:49:00,263 - root - INFO - Received Ping from server
2022-12-14 16:49:00,263 - root - INFO - Responded Pong to server
2022-12-14 16:49:00,266 - root - INFO - Received Ping from server
2022-12-14 16:49:00,267 - root - INFO - Responded Pong to server
2022-12-14 16:49:00,267 - root - INFO - Received Ping from server
2022-12-14 16:49:00,268 - root - INFO - Responded Pong to server
2022-12-14 16:49:00,268 - root - INFO - Received Ping from server
2022-12-14 16:49:00,269 - root - INFO - Responded Pong to server
2022-12-14 16:49:00,276 - root - INFO - Received Ping from server
2022-12-14 16:49:00,277 - root - INFO - Responded Pong to server
2022-12-14 16:51:48,409 - root - INFO - Received Ping from server
2022-12-14 16:51:48,410 - root - INFO - Responded Pong to server
2022-12-14 16:51:48,410 - root - INFO - Received Ping from server
2022-12-14 16:51:48,411 - root - INFO - Responded Pong to server
2022-12-14 16:51:48,411 - root - INFO - Received Ping from server
2022-12-14 16:51:48,414 - root - INFO - Received Ping from server
2022-12-14 16:51:48,414 - root - INFO - Responded Pong to server
2022-12-14 16:51:48,429 - root - INFO - Received Ping from server
2022-12-14 16:51:48,430 - root - INFO - Responded Pong to server
2022-12-14 16:51:48,430 - root - INFO - Received Ping from server
2022-12-14 16:51:48,431 - root - INFO - Responded Pong to server
2022-12-14 16:53:55,306 - root - INFO - Received Pong from server
2022-12-14 16:53:55,309 - root - INFO - Received Pong from server
2022-12-14 16:53:55,310 - root - INFO - Received Pong from server
2022-12-14 16:53:55,311 - root - INFO - Received Pong from server
2022-12-14 16:53:55,313 - root - INFO - Received Pong from server
2022-12-14 16:53:55,314 - root - INFO - Received Pong from server
2022-12-14 16:53:55,315 - root - INFO - Received Pong from server
2022-12-14 16:53:55,316 - root - INFO - Received Pong from server
2022-12-14 16:53:55,317 - root - INFO - Received Pong from server
2022-12-14 16:53:55,319 - root - INFO - Received Pong from server
2022-12-14 16:54:00,261 - root - INFO - Received Ping from server
2022-12-14 16:54:00,261 - root - INFO - Responded Pong to server
2022-12-14 16:54:00,262 - root - INFO - Received Ping from server
2022-12-14 16:54:00,262 - root - INFO - Responded Pong to server
2022-12-14 16:54:00,263 - root - INFO - Received Ping from server
2022-12-14 16:54:00,263 - root - INFO - Responded Pong to server
2022-12-14 16:54:00,266 - root - INFO - Received Ping from server
2022-12-14 16:54:00,266 - root - INFO - Responded Pong to server
2022-12-14 16:54:00,267 - root - INFO - Received Ping from server
2022-12-14 16:54:00,267 - root - INFO - Responded Pong to server
2022-12-14 16:54:00,268 - root - INFO - Received Ping from server
2022-12-14 16:54:00,268 - root - INFO - Responded Pong to server
2022-12-14 16:56:48,410 - root - INFO - Received Ping from server
2022-12-14 16:56:48,411 - root - INFO - Responded Pong to server
2022-12-14 16:56:48,411 - root - INFO - Received Ping from server
2022-12-14 16:56:48,412 - root - INFO - Responded Pong to server
2022-12-14 16:56:48,412 - root - INFO - Received Ping from server
2022-12-14 16:56:48,413 - root - INFO - Responded Pong to server
2022-12-14 16:56:48,433 - root - INFO - Received Ping from server
2022-12-14 16:56:48,434 - root - INFO - Responded Pong to server
2022-12-14 16:56:48,489 - root - INFO - Received Ping from server
2022-12-14 16:56:48,489 - root - INFO - Responded Pong to server
2022-12-14 16:56:48,490 - root - INFO - Received Ping from server
2022-12-14 16:56:48,490 - root - INFO - Responded Pong to server
2022-12-14 16:58:55,305 - root - INFO - Received Pong from server
2022-12-14 16:58:55,310 - root - INFO - Received Pong from server
2022-12-14 16:58:55,311 - root - INFO - Received Pong from server
2022-12-14 16:58:55,312 - root - INFO - Received Pong from server
2022-12-14 16:58:55,315 - root - INFO - Received Pong from server
2022-12-14 16:58:55,316 - root - INFO - Received Pong from server
2022-12-14 16:58:55,319 - root - INFO - Received Pong from server
2022-12-14 16:58:55,320 - root - INFO - Received Pong from server
2022-12-14 16:58:55,323 - root - INFO - Received Pong from server
2022-12-14 16:59:00,266 - root - INFO - Received Ping from server
2022-12-14 16:59:00,266 - root - INFO - Responded Pong to server
2022-12-14 16:59:00,267 - root - INFO - Received Ping from server
2022-12-14 16:59:00,267 - root - INFO - Responded Pong to server
2022-12-14 16:59:00,268 - root - INFO - Received Ping from server
2022-12-14 16:59:00,268 - root - INFO - Responded Pong to server
2022-12-14 16:59:00,271 - root - INFO - Received Ping from server
2022-12-14 16:59:00,271 - root - INFO - Responded Pong to server
2022-12-14 16:59:00,272 - root - INFO - Responded Pong to server
2022-12-14 16:59:00,272 - root - INFO - Received Ping from server
2022-12-14 16:59:00,277 - root - INFO - Received Ping from server
2022-12-14 16:59:00,277 - root - INFO - Responded Pong to server
2022-12-14 17:01:48,428 - root - INFO - Received Ping from server
2022-12-14 17:01:48,428 - root - INFO - Responded Pong to server
2022-12-14 17:01:48,429 - root - INFO - Received Ping from server
2022-12-14 17:01:48,430 - root - INFO - Responded Pong to server
2022-12-14 17:01:48,430 - root - INFO - Received Ping from server
2022-12-14 17:01:48,431 - root - INFO - Responded Pong to server
2022-12-14 17:01:48,431 - root - INFO - Received Ping from server
2022-12-14 17:01:48,432 - root - INFO - Responded Pong to server
2022-12-14 17:01:48,433 - root - INFO - Received Ping from server
2022-12-14 17:01:48,433 - root - INFO - Responded Pong to server
2022-12-14 17:01:48,435 - root - INFO - Received Ping from server
2022-12-14 17:01:48,435 - root - INFO - Responded Pong to server
2022-12-14 17:03:55,304 - root - INFO - Received Pong from server
2022-12-14 17:03:55,305 - root - INFO - Received Pong from server
2022-12-14 17:03:55,306 - root - INFO - Received Pong from server
2022-12-14 17:03:55,312 - root - INFO - Received Pong from server
2022-12-14 17:03:55,313 - root - INFO - Received Pong from server
2022-12-14 17:03:55,316 - root - INFO - Received Pong from server
2022-12-14 17:03:55,317 - root - INFO - Received Pong from server
2022-12-14 17:03:55,320 - root - INFO - Received Pong from server
2022-12-14 17:04:00,259 - root - INFO - Received Ping from server
2022-12-14 17:04:00,260 - root - INFO - Responded Pong to server
2022-12-14 17:04:00,260 - root - INFO - Received Ping from server
2022-12-14 17:04:00,261 - root - INFO - Responded Pong to server
2022-12-14 17:04:00,261 - root - INFO - Received Ping from server
2022-12-14 17:04:00,262 - root - INFO - Received Ping from server
2022-12-14 17:04:00,262 - root - INFO - Responded Pong to server
2022-12-14 17:04:00,266 - root - INFO - Received Ping from server
2022-12-14 17:04:00,266 - root - INFO - Responded Pong to server
2022-12-14 17:04:00,267 - root - INFO - Responded Pong to server
2022-12-14 17:04:00,267 - root - INFO - Received Ping from server
2022-12-14 17:06:48,411 - root - INFO - Received Ping from server
2022-12-14 17:06:48,412 - root - INFO - Responded Pong to server
2022-12-14 17:06:48,412 - root - INFO - Received Ping from server
2022-12-14 17:06:48,413 - root - INFO - Responded Pong to server
2022-12-14 17:06:48,413 - root - INFO - Received Ping from server
2022-12-14 17:06:48,414 - root - INFO - Responded Pong to server
2022-12-14 17:06:48,414 - root - INFO - Received Ping from server
2022-12-14 17:06:48,415 - root - INFO - Received Ping from server
2022-12-14 17:06:48,415 - root - INFO - Responded Pong to server
2022-12-14 17:06:48,417 - root - INFO - Received Ping from server
2022-12-14 17:06:48,418 - root - INFO - Responded Pong to server
2022-12-14 17:08:55,306 - root - INFO - Received Pong from server
2022-12-14 17:08:55,307 - root - INFO - Received Pong from server
2022-12-14 17:08:55,310 - root - INFO - Received Pong from server
2022-12-14 17:08:55,320 - root - INFO - Received Pong from server
2022-12-14 17:08:55,321 - root - INFO - Received Pong from server
2022-12-14 17:08:55,322 - root - INFO - Received Pong from server
2022-12-14 17:09:00,266 - root - INFO - Received Ping from server
2022-12-14 17:09:00,267 - root - INFO - Responded Pong to server
2022-12-14 17:09:00,267 - root - INFO - Received Ping from server
2022-12-14 17:09:00,268 - root - INFO - Responded Pong to server
2022-12-14 17:09:00,268 - root - INFO - Received Ping from server
2022-12-14 17:09:00,269 - root - INFO - Responded Pong to server
2022-12-14 17:09:00,269 - root - INFO - Received Ping from server
2022-12-14 17:09:00,298 - root - INFO - Received Ping from server
2022-12-14 17:09:00,298 - root - INFO - Responded Pong to server
2022-12-14 17:09:00,299 - root - INFO - Received Ping from server
2022-12-14 17:09:00,299 - root - INFO - Responded Pong to server
2022-12-14 17:09:00,300 - root - INFO - Responded Pong to server
2022-12-14 17:11:48,403 - root - INFO - Received Ping from server
2022-12-14 17:11:48,403 - root - INFO - Responded Pong to server
2022-12-14 17:11:48,404 - root - INFO - Received Ping from server
2022-12-14 17:11:48,404 - root - INFO - Responded Pong to server
2022-12-14 17:11:48,405 - root - INFO - Received Ping from server
2022-12-14 17:11:48,406 - root - INFO - Responded Pong to server
2022-12-14 17:11:48,406 - root - INFO - Received Ping from server
2022-12-14 17:11:48,408 - root - INFO - Received Ping from server
2022-12-14 17:11:48,408 - root - INFO - Responded Pong to server
2022-12-14 17:11:48,409 - root - INFO - Received Ping from server
2022-12-14 17:11:48,409 - root - INFO - Responded Pong to server
2022-12-14 17:13:55,315 - root - INFO - Received Pong from server
2022-12-14 17:13:55,316 - root - INFO - Received Pong from server
2022-12-14 17:13:55,317 - root - INFO - Received Pong from server
2022-12-14 17:13:55,319 - root - INFO - Received Pong from server
2022-12-14 17:13:55,324 - root - INFO - Received Pong from server
2022-12-14 17:13:55,327 - root - INFO - Received Pong from server
2022-12-14 17:13:55,328 - root - INFO - Received Pong from server
2022-12-14 17:13:55,332 - root - INFO - Received Pong from server
2022-12-14 17:13:55,333 - root - INFO - Received Pong from server
2022-12-14 17:14:00,255 - root - INFO - Received Ping from server
2022-12-14 17:14:00,256 - root - INFO - Responded Pong to server
2022-12-14 17:14:00,256 - root - INFO - Received Ping from server
2022-12-14 17:14:00,257 - root - INFO - Responded Pong to server
2022-12-14 17:14:00,257 - root - INFO - Received Ping from server
2022-12-14 17:14:00,258 - root - INFO - Responded Pong to server
2022-12-14 17:14:00,258 - root - INFO - Received Ping from server
2022-12-14 17:14:00,259 - root - INFO - Responded Pong to server
2022-12-14 17:14:00,259 - root - INFO - Received Ping from server
2022-12-14 17:14:00,260 - root - INFO - Received Ping from server
2022-12-14 17:14:00,260 - root - INFO - Responded Pong to server
2022-12-14 17:14:00,263 - root - INFO - Received Ping from server
2022-12-14 17:14:00,263 - root - INFO - Responded Pong to server
2022-12-14 17:16:48,406 - root - INFO - Received Ping from server
2022-12-14 17:16:48,406 - root - INFO - Responded Pong to server
2022-12-14 17:16:48,407 - root - INFO - Received Ping from server
2022-12-14 17:16:48,407 - root - INFO - Responded Pong to server
2022-12-14 17:16:48,408 - root - INFO - Received Ping from server
2022-12-14 17:16:48,408 - root - INFO - Responded Pong to server
2022-12-14 17:16:48,409 - root - INFO - Responded Pong to server
2022-12-14 17:16:48,409 - root - INFO - Received Ping from server
2022-12-14 17:16:48,410 - root - INFO - Received Ping from server
2022-12-14 17:16:48,410 - root - INFO - Responded Pong to server
There are 2 limits here:
  • 5 messages ( including connection, subscription, ping, pong, etc) per IP per second to server.
  • 200 streams per connection for futures.
https://dev.binance.vision/t/questions-about-the-websocket-limits/1284/2
https://dev.binance.vision/t/websocket-futures-limits/6260/2
https://dev.binance.vision/t/a-couple-of-questions-about-websocket-limits/2777/2
https://dev.binance.vision/t/lift-up-wss-limits/12411/2
https://dev.binance.vision/t/is-ws-rate-limit-ip-or-connection-releated/12133/2
It seems like these limits are frequently changing and in every other question I read about, different limits are mentioned. Where can I find this information in a clear and up-to-date way?
As you can see, I subscribed to all 13 different subscriptions at the same time and sent ‘pong’ to each of them at the same second. For more than 24 hours, my IP address has not been restricted or banned in any way. I still don’t understand exactly how this works. Could you please share more detailed information?
