**** wss://stream.binance.com → OK ****
Connected to wss://stream.binance.com/ws/btcusdt@kline_1m successfully
Echo: {“e”:“kline”,“E”:1735310022015,“s”:“BTCUSDT”,“k”:{“t”:1735309980000,“T”:1735310039999,“s”:“BTCUSDT”,“i”:“1m”,“f”:4342942101,“L”:4342955151,“o”:“96175.99000000”,“c”:“95950.71000000”,“h”:“96175.99000000”,“l”:“95929.71000000”,“v”:“69.53432000”,“n”:13051,“x”:false,“q”:“6676855.80000510”,“V”:“16.92542000”,“Q”:“1625015.85704960”,“B”:“0”}}
Echo: {“e”:“kline”,“E”:1735310024018,“s”:“BTCUSDT”,“k”:{“t”:1735309980000,“T”:1735310039999,“s”:“BTCUSDT”,“i”:“1m”,“f”:4342942101,“L”:4342955301,“o”:“96175.99000000”,“c”:“95958.48000000”,“h”:“96175.99000000”,“l”:“95929.71000000”,“v”:“69.95630000”,“n”:13201,“x”:false,“q”:“6717349.33638890”,“V”:“17.09974000”,“Q”:“1641743.03368130”,“B”:“0”}}
**** wss://fstream.binance.com → ERROR ****
27/12/2567 21:34:37|Fatal|WebSocket.Connect|WebSocketSharp.WebSocketException: An error has occurred during a TLS handshake. —> System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. —> System.ComponentModel.Win32Exception: The function requested is not supported
— End of inner exception stack trace —
at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, Exception exception)
at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.StartSendBlob(Byte incoming, Int32 count, AsyncProtocolRequest asyncRequest, Boolean renegotiation)
at System.Net.Security.SslState.ProcessReceivedBlob(Byte buffer, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.StartReadFrame(Byte buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.StartReceiveBlob(Byte buffer, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte buffer, AsyncProtocolRequest asyncRequest, Boolean renegotiation)
at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
at System.Net.Security.SslStream.AuthenticateAsClient(String targetHost, X509CertificateCollection clientCertificates, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation)
at WebSocketSharp.WebSocket.setClientStream()
at WebSocketSharp.WebSocket.doHandshake()
at WebSocketSharp.WebSocket.connect()
Disconnected with wss://fstream.binance.com/ws/btcusdt@kline_1m
