wss://stream.binance.com-> ok wss://fstream.binance.com-> Err
wss://fstream.binance.com/stream?streams=btcusdt@aggTrade/btcusdt@markPrice
I’m sending it like this, but it’s not responding. I can only do it a few days ago and suddenly it’s not working, but I don’t know why.
Hi @dydghd2333, are you using any of the futures connectors or hitting the API directly?
Hi, I’m doing futures and I’m doing it with Websoket. I just need a price and funding inquiry.
Just to clarify, you don’t get any response back or you get an explicit error?
How do you also handle the websocket connection and what kind of language/library do you use? Can you post an example of usage?
Bear in mind also that there is a 24hr window that the connection is open, after that is killed and you need to renew it by yourself.
