Hi guys,
I have a serious problem with withdraw endpoints. My php script works with other endpoints very well, but on withdraw endpoint I get this error:
{“code”:-1102,“msg”:“Mandatory parameter ‘amount’ was not sent, was empty/null, or malformed.”}
Please help me.
Thanks.
<?php
$api_key = 'XXXX';
$secret_key = 'YYYY;
$params = [];
$params['coin'] = "USDT";
$params['address'] = "TXxxx";
$params['network'] = "TRX";
$params['amount'] = 20;
$query = http_build_query($params, '', '&');
date_default_timezone_set('UTC');
$params['timestamp'] = number_format(microtime(true)*1000,0,'.','');
$signature = hash_hmac('sha256', $query, $secret_key);
$endpoint = "https://api.binance.com/sapi/v1/capital/withdraw/apply";
$params['signature'] = $signature; // signature needs to be inside BODY
$query = http_build_query($params, '', '&'); // rebuilding query
$curl_handle = curl_init();
curl_setopt($curl_handle, CURLOPT_USERAGENT, "User-Agent: Mozilla/4.0 (compatible; PHP Binance API)");
curl_setopt($curl_handle, CURLOPT_HTTPHEADER, array(
'X-MBX-APIKEY: ' . $api_key,
curl_setopt($curl_handle, CURLOPT_URL, $endpoint . '?' . $query);
curl_setopt($curl_handle, CURLOPT_POST, true);
curl_setopt($curl_handle, CURLOPT_POSTFIELDS, $query);
curl_setopt($curl_handle, CURLOPT_HEADER, false);
curl_setopt($curl_handle, CURLOPT_RETURNTRANSFER, true);
$res = curl_exec($curl_handle);
curl_close($curl_handle);
error_log(print_r($res,true));
query => coin=USDT&address=TXxxx&network=TRX&amount=20×tamp=1627136382958&signature=8040054c1abfxxx5281fd34f8
