I was wondering why is there no /sapi/v1/asset/tradeFee
endpoint available in Testnet?
Calling this endpoint gives 404
The Spot Testnet only supports /api/*
endpoints.
/sapi/*
endpoints are not supported.
Thanks for the answer! Are there any plans to add support (or at least partial support?). Writing integration tests is near impossible - you need to mock all of the data from the production and pray “it just works”.
The team is aware of the request but no plans for the near future.
Thanks for the info. Hope you could bump a +1 from me… this feature would be very handy for people who are doing integrations with Binance!
