What is the reason that the sellable quantity is shrinked and not the same as the bought quantity? For example, if I buy ETHUSDC
with a quantity of 0.0707ETH
(and commission of 0.00007070ETH
). The trade execution shows that the buy 0.0707ETH
was successfully. Then I expect, that I have 0.0707ETH
, but that’s not the case, because the balance shows me a real quantity of 0.0706913
? Do I need to substract the commission from my bought quantity (0.0707 - 0.00007070 = 0.0706293
)? But if so, then 0.0706293
is not 0.0706913
. There is a difference of 0.000062
My question is:
I bought 0.0707ETH
and the fill shows it, why does the balance shows 0.0706913ETH
