LIG-JY
1
The other APIs work fine, but when you try to use
“GET https://testnet.binancefuture.com/futures/data/openInterestHist?symbol=BTCUSDT&period=1d” it doesn’t work.
Is it impossible to get openInterest from testnet?
I’m using javaconnector(GitHub - binance/binance-connector-java)
dino
2
Hi, I think this endpoint is not available from the futures testnet.
LIG-JY
3
Thanks!
The API that passes “period” as a mandatory parameter doesn’t seem to be available on testnet at the moment!
