url = “wss://stream.binance.com:9443/ws/stream?streams=”;
string url2 = url.ToLower();
webSocketClient = new WebSocket(url2);
webSocketClient.OnError += new EventHandler<WebSocketSharp.ErrorEventArgs>(webSocketClient_Error);
webSocketClient.OnOpen += new EventHandler(webSocketClient_Opened);
webSocketClient.OnClose += new EventHandler<WebSocketSharp.CloseEventArgs>(webSocketClient_Closed);
webSocketClient.OnMessage += new EventHandler(webSocketClient_MessageReceived);
webSocketClient.ConnectAsync();
private async void webSocketClient_Opened(object sender, EventArgs e)
Subscribe();
private void Subscribe()
var requestString = $"{{\"method\": \"SUBSCRIBE\", \"params\": [\"!bookTicker\"], \"id\": 1}}";
webSocketClient.Send(requestString);
MJW
November 16, 2020, 2:55am
2
Please convert the JSON object to a string before ws.send; Not sure how the double curly brackets do it
here they are, I also tried this , maybe the address is not the same or I don’t understand the syntax already
webSocketClient.Send(JsonConvert.SerializeObject(requestString));
public void start()
url = "wss://stream.binance.com:9443/ws";
webSocketClient.OnMessage += new EventHandler<MessageEventArgs>(webSocketClient_MessageReceived);
// webSocketClient.Connect();
while (!webSocketClient.IsAlive)
Savelog("Connecting via WebSocket to Binance......\r\n", Color.DarkGreen);
Thread.Sleep(2000);
//SubscribeStream();
t.Elapsed += new System.Timers.ElapsedEventHandler(heatBeat);
t.Start();
Subscribe();
// webSocketClient.Send(requestString);
“{“error”:{“code”:2,“msg”:“Invalid request: invalid type: string “{\“method\”: \“SUBSCRIBE\”, \“params\”: [\”!bookTicker\”], \“id\”: 1}”, expected internally tagged enum at line 1 column 71"}}"
MJW
November 16, 2020, 10:36pm
7
This is more like a java coding problem. Just make sure you connect to “wss://stream.binance.com:9443/ws” and send a string converted from below JSON object:
{“method”: “SUBSCRIBE”,“params”:["!bookTicker"],“id”: 1}
(Still suspect why you put double curly brackets)
that’s right !!! I didn’t see the brackets
