Hello i would like to be able to place with binance API futures a LONG order that gets executed at a specific entry price for example say of 0.9 and set target price as 1.1 and stop price 0.85.
What type of order should i specify ? Thanks
up to now i am trying LIMIT type but i am not sure it’s correct
As I understand, you are looking for one stop limit order, which is when the order is triggered at one price, it will place the actually limit order at another price.
If so you will only need to place one order with:
