Hi! When I get exchange information via the “GET /api/v3/exchangeInfo” endpoint, I see these two fields that seem to indicate the same information. Am I missing something important here?
Thanks!
Hi.
So far they should be the same but quotePrecision will be removed in future API versions (v4+).
Please refer to change log 2020-04-25 https://binance-docs.github.io/apidocs/spot/en/#change-log
Great! Thank you so much for the clarification.
