Some Binance responses return a boolean isWorking
field. This field is completely undocumented, and nothing shows up on Google either. I’ve searched these forums, and can’t find any discussion of it either.
The reason I ask is because I noticed some strange API behaviour — which might be a bug, or could be explained by isWorking
(if I had any idea what it means)…
- I made a
DELETE
request for an existing order. The order’s status wasNEW
. - Binance returned a response for the order with a status of
CANCELED
. - A few moments later, I made a
GET
request for the same order. The response came back with the statusNEW
again — despite having just been reported asCANCELED
in the previous request. - The only difference I could tell was that the second response had the
isWorking
field, which was set tofalse
.isWorking
was not returned in the first response.
