When I ping the key always get
{"code":-1125,"msg":"This listenKey does not exist."}
please share which endpoint returned this error and what’s the parameter sent in the request?
thanks
http PUT with headers
headers.insert("User-Agent","Mozilla/4.0 (compatible; Node Binance API)");
headers.insert("Content-Type","application/x-www-form-urlencoded");
headers.insert("X-MBX-APIKEY", access_key);
https://api.binance.com/api/v3/userDataStream?listenKey=${listenKey}
ping every 10 minutes, always get This listenKey does not exist, then retry(generate a new key)
Why the listenKey could be invalid?
[2020-06-10T23:46:20Z ERROR ws_client::binance] binance ping error listen_key D59cIClGAX8Zi50d18YDJVomGICnysDrTSkFMi0DKY3VXLLcVKU0gSOQD275 ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-10T23:46:20Z INFO ws_client::binance] binance delete listen_key D59cIClGAX8Zi50d18YDJVomGICnysDrTSkFMi0DKY3VXLLcVKU0gSOQD275, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-10T23:56:22Z ERROR ws_client::binance] binance ping error listen_key BnsAZnsYAeCkBo0iZywA5cOEFU67WQrLmlkY52KxRByp0Ca6u36MuSzDutfF ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-10T23:56:22Z INFO ws_client::binance] binance delete listen_key BnsAZnsYAeCkBo0iZywA5cOEFU67WQrLmlkY52KxRByp0Ca6u36MuSzDutfF, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:06:25Z ERROR ws_client::binance] binance ping error listen_key W8EzoOy7IF7e8OBpccaWo2BdZqjy8lSdP6K1FcBFxIE8xPUVlcK72bVsA27b ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:06:25Z INFO ws_client::binance] binance delete listen_key W8EzoOy7IF7e8OBpccaWo2BdZqjy8lSdP6K1FcBFxIE8xPUVlcK72bVsA27b, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:16:27Z ERROR ws_client::binance] binance ping error listen_key rQldmIUyuHCRwsj7VYA0L13uCA87CT3ZxMZqP9FM8K4mzLYmCDhXgz7X9IHy ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:16:27Z INFO ws_client::binance] binance delete listen_key rQldmIUyuHCRwsj7VYA0L13uCA87CT3ZxMZqP9FM8K4mzLYmCDhXgz7X9IHy, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:26:29Z ERROR ws_client::binance] binance ping error listen_key xhy0LXhvCIDuyyrgGekMj3efy5quYKEZNmnYbCsrw2SNqITtSHhGT6Stnn7r ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:26:29Z INFO ws_client::binance] binance delete listen_key xhy0LXhvCIDuyyrgGekMj3efy5quYKEZNmnYbCsrw2SNqITtSHhGT6Stnn7r, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:36:31Z ERROR ws_client::binance] binance ping error listen_key flNqzIlPF494WjCTPPBnXZsv0ZX0iOCPYng4kyQwqqYVqDfhzTtQevdSfa4h ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:36:31Z INFO ws_client::binance] binance delete listen_key flNqzIlPF494WjCTPPBnXZsv0ZX0iOCPYng4kyQwqqYVqDfhzTtQevdSfa4h, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:46:33Z ERROR ws_client::binance] binance ping error listen_key 6ohJ0eKhkLlkLp5QklQMHOgUKUZqfTsP7qjNCbfhri2YeMFYAT1E3zwqjiSQ ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:46:33Z INFO ws_client::binance] binance delete listen_key 6ohJ0eKhkLlkLp5QklQMHOgUKUZqfTsP7qjNCbfhri2YeMFYAT1E3zwqjiSQ, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:56:35Z ERROR ws_client::binance] binance ping error listen_key czHCDbOrsZd3ztegp9MKsn6X7h0P5H3TqDRArX66V3vcKeFHJ55rhO0tT5oj ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T00:56:35Z INFO ws_client::binance] binance delete listen_key czHCDbOrsZd3ztegp9MKsn6X7h0P5H3TqDRArX66V3vcKeFHJ55rhO0tT5oj, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:06:37Z ERROR ws_client::binance] binance ping error listen_key r52na8pDYSTl6kUu2b3u7TUVFVmgCnyxTbYKHM4RAB1itd5Wjw89n7ynTO98 ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:06:37Z INFO ws_client::binance] binance delete listen_key r52na8pDYSTl6kUu2b3u7TUVFVmgCnyxTbYKHM4RAB1itd5Wjw89n7ynTO98, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:16:39Z ERROR ws_client::binance] binance ping error listen_key xCQZA3TkJ3wks2Mi51pNLeTlvQ9Zc5oIrrTIILdKOWu5t99msATbPBho5R5e ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:16:39Z INFO ws_client::binance] binance delete listen_key xCQZA3TkJ3wks2Mi51pNLeTlvQ9Zc5oIrrTIILdKOWu5t99msATbPBho5R5e, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:26:41Z ERROR ws_client::binance] binance ping error listen_key Xg9BLtqndIYaqUDVPXkMxH02t4x9SouzH5TsUXBuFkf5lfTVnNr9XhtA8Ai8 ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:26:41Z INFO ws_client::binance] binance delete listen_key Xg9BLtqndIYaqUDVPXkMxH02t4x9SouzH5TsUXBuFkf5lfTVnNr9XhtA8Ai8, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:36:43Z ERROR ws_client::binance] binance ping error listen_key FP8CQaZu4TAcHZuWxMHEMCI6ub81pxhHnWFHeHXW3Z86SaB8hsRrzzLETx7B ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:36:43Z INFO ws_client::binance] binance delete listen_key FP8CQaZu4TAcHZuWxMHEMCI6ub81pxhHnWFHeHXW3Z86SaB8hsRrzzLETx7B, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:46:45Z ERROR ws_client::binance] binance ping error listen_key iEjyBzTg20OVT9odBdeTFsCty96sDSuPgab6nPnziyH2FykuqI4K6smbKdwZ ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:46:45Z INFO ws_client::binance] binance delete listen_key iEjyBzTg20OVT9odBdeTFsCty96sDSuPgab6nPnziyH2FykuqI4K6smbKdwZ, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:56:47Z ERROR ws_client::binance] binance ping error listen_key zjQoTz6WDTdSvvdH1xVPCC6z0sr3UCHXflnFMGfLDrdVummixsE31RNlgFM7 ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T01:56:47Z INFO ws_client::binance] binance delete listen_key zjQoTz6WDTdSvvdH1xVPCC6z0sr3UCHXflnFMGfLDrdVummixsE31RNlgFM7, response {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T02:06:50Z ERROR ws_client::binance] binance ping error listen_key Bl1Egsm04dP2rrjPCVEuVOI8i4gK7vGnua2GCMDu70UC4W3qSWy9wWx0f2XZ ping expect {} but recv {"code":-1125,"msg":"This listenKey does not exist."}
[2020-06-11T02:06:50Z INFO ws_client::binance] binance delete listen_key Bl1Egsm04dP2rrjPCVEuVOI8i4gK7vGnua2GCMDu70UC4W3qSWy9wWx0f2XZ, response {"code":-1125,"msg":"This listenKey does not exist."}
it seems that this listenKey is not valid, please try to generate a new one and PUT to renew.
it should work then
Sorry this log is still very limited, I’m not sure how did you get this error.
But in order to renew the listenKey, it has to send a RESTful request
PUT /api/v3/userDataStream
, providing the valid listen key for the parameter listenKey
in cURL, can be like:
curl -H "Context-Type: application/json" --request PUT 'https://api.binance.com/api/v3/userDataStream?listenKey=xxxxx'
