I implementing a c++ wrapper to the api using boost::beast, and I have issues with the POSTs.
(GETs works fine)
I got {“code”:-1002,“msg”:“You are not authorized to execute this request.”} which i really do not understand. When I perform the same POST from the same machine using cUrl everything is fine.
Anyone have an idea from where it can come?
Thanks,
Trog
