Websockets to binance.org
Hello!
Since yesturday I cant connect to binance.org websockets anymore!
Tryed to connect to “testnet-dex.binance.org” and “dex.binance.org” but I allways get a “failing connection with code 1006”. I tried from 3 different systems with IPs from EU and USA. Are there any service issues?
Yesturday this popped up in my Logs:
2024-05-07 15:19:20,901 [DEBUG ] 3903 140105926833728 client: < X-Cache: Error from cloudfront
Todday I dont see this error, but I am not able to connect with this Logs:
2024-05-08 13:24:17,974 [DEBUG ] 5194 140397221594688 protocol: = connection is CONNECTING
2024-05-08 13:24:18,027 [DEBUG ] 5194 140397221594688 client: > GET /api/ws/$all@allMiniTickers HTTP/1.1
2024-05-08 13:24:18,028 [DEBUG ] 5194 140397221594688 client: > Host: dex.binance.org
2024-05-08 13:24:18,029 [DEBUG ] 5194 140397221594688 client: > Upgrade: websocket
2024-05-08 13:24:18,030 [DEBUG ] 5194 140397221594688 client: > Connection: Upgrade
2024-05-08 13:24:18,031 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Key: kcq/3jlK1238TKviNOsoQA==
2024-05-08 13:24:18,031 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Version: 13
2024-05-08 13:24:18,032 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
2024-05-08 13:24:18,032 [DEBUG ] 5194 140397221594688 client: > User-Agent: unicorn-binance-websocket-api_2.6.0-python_3.10.12
2024-05-08 13:24:27,859 [DEBUG ] 5194 140397221594688 protocol: ! failing connection with code 1006
2024-05-08 13:24:27,860 [DEBUG ] 5194 140397221594688 protocol: x closing TCP connection
2024-05-08 13:24:28,863 [DEBUG ] 5194 140397221594688 protocol: ! timed out waiting for TCP close
2024-05-08 13:24:28,864 [DEBUG ] 5194 140397221594688 protocol: x aborting TCP connection
2024-05-08 13:24:28,865 [DEBUG ] 5194 140397221594688 protocol: = connection is CLOSED
2024-05-08 13:24:29,108 [DEBUG ] 5194 140397221594688 protocol: = connection is CONNECTING
2024-05-08 13:24:29,160 [DEBUG ] 5194 140397221594688 client: > GET /api/ws/$all@allMiniTickers HTTP/1.1
2024-05-08 13:24:29,161 [DEBUG ] 5194 140397221594688 client: > Host: dex.binance.org
2024-05-08 13:24:29,161 [DEBUG ] 5194 140397221594688 client: > Upgrade: websocket
2024-05-08 13:24:29,162 [DEBUG ] 5194 140397221594688 client: > Connection: Upgrade
2024-05-08 13:24:29,163 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Key: KzxHLchY1VGUJiE2AwnupA==
2024-05-08 13:24:29,164 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Version: 13
2024-05-08 13:24:29,164 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
2024-05-08 13:24:29,164 [DEBUG ] 5194 140397221594688 client: > User-Agent: unicorn-binance-websocket-api_2.6.0-python_3.10.12
2024-05-08 13:24:38,991 [DEBUG ] 5194 140397221594688 protocol: ! failing connection with code 1006
2024-05-08 13:24:38,993 [DEBUG ] 5194 140397221594688 protocol: x closing TCP connection
2024-05-08 13:24:39,995 [DEBUG ] 5194 140397221594688 protocol: ! timed out waiting for TCP close
2024-05-08 13:24:39,996 [DEBUG ] 5194 140397221594688 protocol: x aborting TCP connection
2024-05-08 13:24:39,997 [DEBUG ] 5194 140397221594688 protocol: = connection is CLOSED
2024-05-08 13:24:40,229 [DEBUG ] 5194 140397221594688 protocol: = connection is CONNECTING
2024-05-08 13:24:40,280 [DEBUG ] 5194 140397221594688 client: > GET /api/ws/$all@allMiniTickers HTTP/1.1
2024-05-08 13:24:40,281 [DEBUG ] 5194 140397221594688 client: > Host: dex.binance.org
2024-05-08 13:24:40,282 [DEBUG ] 5194 140397221594688 client: > Upgrade: websocket
2024-05-08 13:24:40,283 [DEBUG ] 5194 140397221594688 client: > Connection: Upgrade
2024-05-08 13:24:40,283 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Key: 1j5gQWXGso+RfAubZ8/7Eg==
2024-05-08 13:24:40,284 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Version: 13
2024-05-08 13:24:40,284 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
2024-05-08 13:24:40,284 [DEBUG ] 5194 140397221594688 client: > User-Agent: unicorn-binance-websocket-api_2.6.0-python_3.10.12
2024-05-08 13:24:50,115 [DEBUG ] 5194 140397221594688 protocol: ! failing connection with code 1006
2024-05-08 13:24:50,117 [DEBUG ] 5194 140397221594688 protocol: x closing TCP connection
2024-05-08 13:24:51,120 [DEBUG ] 5194 140397221594688 protocol: ! timed out waiting for TCP close
2024-05-08 13:24:51,121 [DEBUG ] 5194 140397221594688 protocol: x aborting TCP connection
2024-05-08 13:24:51,122 [DEBUG ] 5194 140397221594688 protocol: = connection is CLOSED
2024-05-08 13:24:51,356 [DEBUG ] 5194 140397221594688 protocol: = connection is CONNECTING
2024-05-08 13:24:51,410 [DEBUG ] 5194 140397221594688 client: > GET /api/ws/$all@allMiniTickers HTTP/1.1
2024-05-08 13:24:51,410 [DEBUG ] 5194 140397221594688 client: > Host: dex.binance.org
2024-05-08 13:24:51,411 [DEBUG ] 5194 140397221594688 client: > Upgrade: websocket
2024-05-08 13:24:51,412 [DEBUG ] 5194 140397221594688 client: > Connection: Upgrade
2024-05-08 13:24:51,412 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Key: hz+bmH8eIsNlGmufMNIw4g==
2024-05-08 13:24:51,413 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Version: 13
2024-05-08 13:24:51,414 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
2024-05-08 13:24:51,414 [DEBUG ] 5194 140397221594688 client: > User-Agent: unicorn-binance-websocket-api_2.6.0-python_3.10.12
2024-05-08 13:25:01,251 [DEBUG ] 5194 140397221594688 protocol: ! failing connection with code 1006
2024-05-08 13:25:01,253 [DEBUG ] 5194 140397221594688 protocol: x closing TCP connection
2024-05-08 13:25:02,257 [DEBUG ] 5194 140397221594688 protocol: ! timed out waiting for TCP close
2024-05-08 13:25:02,258 [DEBUG ] 5194 140397221594688 protocol: x aborting TCP connection
2024-05-08 13:25:02,260 [DEBUG ] 5194 140397221594688 protocol: = connection is CLOSED
2024-05-08 13:25:02,504 [DEBUG ] 5194 140397221594688 protocol: = connection is CONNECTING
2024-05-08 13:25:02,557 [DEBUG ] 5194 140397221594688 client: > GET /api/ws/$all@allMiniTickers HTTP/1.1
2024-05-08 13:25:02,558 [DEBUG ] 5194 140397221594688 client: > Host: dex.binance.org
2024-05-08 13:25:02,559 [DEBUG ] 5194 140397221594688 client: > Upgrade: websocket
2024-05-08 13:25:02,559 [DEBUG ] 5194 140397221594688 client: > Connection: Upgrade
2024-05-08 13:25:02,560 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Key: atqC4hWK0fZKoXdztTY86A==
2024-05-08 13:25:02,560 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Version: 13
2024-05-08 13:25:02,561 [DEBUG ] 5194 140397221594688 client: > Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
For BNB Chain related topics, please use:
Forum: https://forum.bnbchain.org/
Telegram: Telegram: Contact @BNBchaincommunity
Will do so, thanks!
Not sure that this telegram channel is the correct one:
