您好 我想咨询一下websocket中单一原始 streams 格式为 /ws/
和实时订阅/取消数据流这两者的区别,还有这个streams是什么格式
There is no difference when subscribing via URL or websocket message when using /ws/.
The format of the stream response depends on the stream you subscribe to. More info here https://binance-docs.github.io/apidocs/spot/cn/#websocket
