Hi all,
My Python Websocket stops receiving data a fixed times (e.g. 10.00u or 16.00)u. This after running for quitte some hours. How can I keep it alive? Any sample scripts?
It start with:
binance_socket_manager._start_futures_socket(‘ethusdt@trade’, self.handle_tick)
Thx! WJ
Hi. Could you please check the following points?
- How many hours had it past since the connection was established? Single connection is only valid for 24 hrs. https://binance-docs.github.io/apidocs/spot/en/#websocket-market-streams
- If you are using a library, you may want to check its implementation details, such as how it keeps the connection alive or in what condition, it terminates the connection.
- Maybe this example is not highly relevant but you can take a look at it and see how it handles the connection. https://github.com/binance-exchange/binance-toolbox-python/blob/master/spot/manage_local_order_book.py
Thx for your reply. How can I keep it running after 24 hours? I want it to run continuously…
class WebSocketTester:
def __init__(self, ):
self.client = Client()
self.start_socket()
def start_socket(self):
binance_socket_manager = BinanceSocketManager(self.client)
binance_socket_manager._start_futures_socket('ethusdt@trade', self.handle_tick)
conn_key = binance_socket_manager.start()
except Exception as e:
print('Exception in TimerWS.start_socket:', e)
def handle_tick(self, msg):
print(msg)
if __name__ == '__main__':
po = WebSocketTester()
