Hi, I’d like to ask for your help. I am using ws and I would also like to use sleep() in my strategy. Unfortunately, after each use of sleep() I get a delayed message from ws. Any idea what to do about it? Thank you.
from time import sleep
import websocket, datetime, pprint, json, config
import numpy as np
from binance.enums import *
client = Client(config.api_key, config.api_secret)
SymoblTrading = ‘BTCUSDT’
symbol = ‘btcusdt’
ask = None
high = None
highs =
def on_message(ws, message):
print(str(datetime.datetime.now()) + ": ")
json_message = json.loads(message)
print(json_message)
if 'asks' in json_message:
global ask
ask_string = json_message['asks'][0][0]
ask = float(ask_string)
print("Ask")
print(ask)
if 'h' in json_message:
global high
high_string = json_message['h']
high = float(high_string)
print("High")
print(high)
if ask is not None and high is not None:
sleep(30)
def on_error(ws, error):
print(error)
def on_close(ws, close_msg):
print("### closed ###" + close_msg)
def streamKline(symbol):
websocket.enableTrace(False)
socket = f’wss://stream.binance.com:9443/ws/{symbol}@ticker_1h/{symbol}@depth5’
ws = websocket.WebSocketApp(socket,
on_message=on_message,
on_error=on_error,
on_close=on_close)
ws.run_forever()
streamKline(symbol)
