I got a new computer to run code so I moved the program to 2nd computer and it does not work. I found that the websocket was causing the problem. used await socket.recv() and it blocks the code. it works in spot but not in futures. why is it not working
async def main():
print('Start')
#async with ws.connect('wss://fstream.binance.com/stream?streams=btcusdt@kline_1m') as socket:
async with ws.connect('wss://stream.binance.com:9443/stream?streams=btcusdt@kline_1m') as socket:
response = await socket.recv()
print(response)
As this program can run successfully without any issue in one laptop, it’s not an issue on the program itself. Besides, I assume your two devices are tested in the same environment, that is they may share the same network and IP address. So the possible root cause is at the local side. Here are some points that may help you resolve it:
Enable or find out error logs.
Check the local network settings, including firewall, socket permission, etc.
Check if all the necessary certificates are up-to-date.
I did manage to run the code
However there was no error and I did not change any of the code.
I was reading some code and reran it and it worked.
Dont know what happened but it did work, without changing anything
