Does anyone know what is the latest Binance API function version of start_multiplex_socket,
start_user_socket, start_symbol_ticker_socket or similar from
BinanceSocketManager or another module to start socket connexion.
Would be very much appreciated !
it seems you’re using python-binance
, which is not the official library and therefore we don’t support. Although if you’re keen to explore to the official one, you can check at Binance Public API Connector Python — binance-connector documentation or GitHub - binance/binance-connector-python: a simple connector to Binance Public API .
Oh, so I could try with this library then,
Thanks a lot.
However, binance_connector is not recognized on Anaconda. It says the package in unavailable
jonte
May 30, 2023, 12:32am
5
Hi, it’s binance-connector
actually. Try that instead.
pip install binance-connector
is the recommended PyPi installation command.
