subscribe many coins on both spot ans swap market by below codes:
import json
import websocket
spot_ws = websocket.create_connection('wss://stream.binance.com:9443/ws')
swap_ws = websocket.create_connection('wss://fstream.binance.com/ws')
symbols = ["BTCUSDT", "ETHUSDT", "SOLUSDT", "BNBUSDT", "XRPUSDT", "DOGEUSDT", "ADAUSDT", "TRXUSDT", "AVAXUSDT",
"LINKUSDT", "DOTUSDT", "BCHUSDT", "NEARUSDT", "LTCUSDT", "ICPUSDT", "FETUSDT", "UNIUSDT"]
sub_list = list(map(lambda x: x.lower() + '@kline_1m', symbols))
spot_ws.send(json.dumps({"method": "SUBSCRIBE", "params": sub_list, "id": 1}))
swap_ws.send(json.dumps({"method": "SUBSCRIBE", "params": sub_list, "id": 1}))
spot_ws.recv()
swap_ws.recv()
spot_completed_num = 0
spot_completed = False
while True:
for wsi in [spot_ws, swap_ws]:
if spot_completed and wsi == spot_ws:
continue
datai = json.loads(wsi.recv())
if datai['k']['x']:
if wsi == spot_ws:
spot_completed_num += 1
print('spot', datai['k']['s'])
elif wsi == swap_ws:
print('swap', datai['k']['s'])
if spot_completed_num == len(symbols):
wsi.close()
spot_completed = True
print('spot closed')
else:
if wsi == spot_ws:
print('spot not completed', datai['k']['s'])
print('swap not completed', datai['k']['s'])
I never received completed bars from swap webscoket until the spot websocket was completed or the swap websocket was alse closed when close spot websocket.
