Hi all,
I am looking for an example or even somebody who has been able to place an oco-order with a trailing delta on the above leg and the below leg as described here:
They have updated the binance-connector api to version 3.8.0, but I am still unable to place an oco-order as per the description in the api documents.
If I leave the abovePrice empty (as per document allowed) I get an error message saying I need to give the mandatory abovePrice.
If I give an abovePrice I get the messsage that I send the not required aboveTrailingDelta
anybody has a solution?
To be sure we understand the issue, can you send your exact request or the list of parameters you did fill?
Depending on the order type for aboveType
, will determine the combination of parameters required for that request.
You can refer to the table under New Order Placement .
If the aboveType
is STOP_LOSS_LIMIT
then you would need aboveTimeInForce
, abovePrice
, aboveStopPrice
or aboveTrailingDelta
If it’s STOP_LOSS
then aboveStopPrice
is needed.
This is also assuming that everything else being passed (e.g. parameters for the belowType
in the request is correct, so the request would help to see where the issue is.
