Using Spot Wallet as Backup Source of Funding on Binance Card ... including also Flexible Savings
Based on Using Spot Wallet as Backup Source of Funding on Binance Card | Binance Support
How does it work?
When your Funding Wallet balance is insufficient to pay for a transaction, the system will automatically use the funds from your Spot Wallet to pay for the full amount of the transaction. However, if your Spot Wallet balance is also insufficient, the transaction will be declined.
Feature request
if your Spot Wallet balance is also insufficient, the system will automatically use the corresponding funds from your Flexible Savings
I personally would use more the binance card knowing that I could reap the benefits of the Flexible Savings, e.g. BUSD
Thank you for your feedback. It maybe better to redeem the flexible savings in advance into the spot wallet.
