Using Binance US API from Europe
I am developing a bot platform. Our server is located in Europe. We are introducing support for Binance US, but I would like to know if there is any issue by using an European IP to access Binance US through API. Thanks in Advance.
Hello, I don’t think you’ll be able to access Binance US from Europe, since the product is build for US only. If you want to get more details, you can reach out to the customer support. The conditions are the same for API and UI.
