websockets.exceptions.ConnectionClosedError: received 3001 (registered) illegal request; then sent 3001 (registered) illegal request
Hi, could you please explain me this issue? I can’t find something similar from other forum users.
I use a lot of socket connections, but I take into account all the explicit limitations of the API
It might be related with handling of ping frames.
API documentation has:
- The websocket server will send a
ping frame
every 3 minutes. If the websocket server does not receive a pong frame
back from the connection within a 10 minute period, the connection will be disconnected. Unsolicited pong frames
are allowed.
If you respond the received ping frame with a incorrect message format, the disconnection can happen.
Thanks a lot. I’ll try to handle this case
