I am using testnet to not only understand how the API works generally but more specifically understand the flow of orders. To the best of my knowledge, no fees apply on the testnet, a limitation that I feel shouldn’t apply as it hinders understanding of the API. The testnet should, in my opinion, replicate the same conditions found on mainnet so as to be as close as possible to the real thing.
The question I have is this: when placing a LIMIT order and specifying a (base) quantity, will the amount that gets filled be that quantity OR will it the quantity with fees deducted? For example, let’s say I wish to buy 1 BTC (quote is USDT) – will the order on mainnet fill with 1 BTC received (and .001 extra paid in fees) OR will it fill with .999 (1-.001) BTC?
