Un documented error code || {"code":2,"msg":"参数异常"}
I am send QR image in chat through API,
using c2c messaging docs, i was properly able to send messages and receive and websocket everything working fine,
spot api most endpoints are working fine, but for sending Image in chat, We have to obtain a presigned URL for that
I am unable to get that,
this is my relevent JAVA code
private final String IMAGE_PRESIGNED_URL = "/sapi/v1/c2c/chat/image/pre-signed-url";
and
in order to get the presigned URL
public String retrieveImagePreSignedUrl() {
        String fileName = UUID.randomUUID().toString();
        Map<String, Object> bodyParameters = new HashMap<>();
        bodyParameters.put("imageName", fileName);
        return requestHandler.sendSignedRequest(baseUrl, IMAGE_PRESIGNED_URL, null, HttpMethod.POST, showLimitUsage,bodyParameters);
this is giving me below exception
  1. this is the first time i am receiving error in chinese
  2. the response code received is 500 (usually comes in 4XX range)
  3. the sendSignedRequest method is working fine coz even below code to get Ad detail is working fine
   public String getAdDetailsByMerchantNo( String merchantNo, Map<String, String> headers) {
        Map<String, Object> parameters = new HashMap<>();
        if (merchantNo != null && !merchantNo.isEmpty()) {
            parameters.put("merchantNo", merchantNo);
        return requestHandler.sendSignedRequest(baseUrl, GET_AD_DETAILS_BY_MERCHANT_NO, parameters, HttpMethod.GET, showLimitUsage);
below is the actual response i am getting
Request :
=== BINANCE API REQUEST ===
URL: https://api.binance.com/sapi/v1/c2c/chat/image/pre-signed-url?signature=52bf4ba70dde8dbbaf65c7709b20725d90d1741081465782cec6150e608c290a&timestamp=1749479641275
Method: POST
Headers: User-Agent: binance-connector-java/3.4.1
Content-Type: application/x-www-form-urlencoded
X-MBX-APIKEY:
Body: {“imageName”:“1f17db38-82ee-46e3-a81f-d949ebab488b”}
Response :
=== BINANCE API RESPONSE ===
Status Code: 500
Status Message:
Headers: content-type: application/json
content-length: 31
date: Mon, 09 Jun 2025 14:34:03 GMT
expires: 0
server: nginx
x-sapi-used-uid-weight-1m: 5000
strict-transport-security: max-age=31536000; includeSubdomains
x-frame-options: SAMEORIGIN
x-xss-protection: 1; mode=block
x-content-type-options: nosniff
content-security-policy: default-src ‘self’
x-content-security-policy: default-src ‘self’
x-webkit-csp: default-src ‘self’
cache-control: no-cache, no-store, must-revalidate
pragma: no-cache
x-cache: Error from cloudfront
via: 1.1 857ce214a257a73bd9afdb1c9b13c094.cloudfront.net (CloudFront)
x-amz-cf-pop: DEL51-P6
x-amz-cf-id: f_zPLXHp39tkc82hnKRiz0zdCjEFs7L08L0vr_PXa4NcbL3hpg-DzA==
Body: {“code”:2,“msg”:“参数异常”}
There is unfortunately only one C2C API available in the documentaion: Get C2C Trade History | Binance Open Platform
If you are a verified P2P merchant, please kindly contact Customer Support team: https://www.binance.com/en/chat
Hey @Krishan_Kumar how are u?
Have you found a solution to send the images?
In my case, it gives me the error “login first.”
