troubles installing binance
Hey there are many different api’s available and i only was able to install binance.0.3 but i get the error binance.client not found… can someone help me setup a development enviroement for python3 and the binance api please ?
which library are you referring to? If you’re looking for a library to use the Binance API, I recommend checking out: GitHub - binance/binance-connector-python: Simple connector to Binance Public API
