Tradingview webhook send signal but binance execute only some order
I used tradingview and binance Webhook to create order. Tradingview alert is working correctly as per strategy but binance execute only some order from the signal. Is anyone used to face this problem
This is binance order history
compare to signal that create from tradingview
I found this problem in other time frame aswell
Please help if you know any solution
Same problem here , Some of Tradingview webhook sent but Binance never received . searched in failed signals but (Never received) . And yes I am sure I set up everything correctly .
Reach out to binance support but they tell that this problem should be contact Tradingview. Biancne say their system is normal. so I have reached out Tradingview, they test webhook sent to binance server and this is their answer
