TradeView data changed (?)
While investigating a completely different issue I have noticed data discrepancy in Binance Futures testnet TradeView: the BTCUSDT perpetual 1m candle for 9:20 (UTC) viewed at 9:22:11 (UTC) had close price 47719.20 (-11.40), while the same candle viewed at 9:40:19 (UTC) had close price 47693.50 (-37.10).
Does that mean the testnet data could change in such a way? Or I am missing something here?
Thanks in advance for any response.
No, this should not be the case. However since this the information was obtained via the UI it may not be necessarily an issue with the API.
I suggest looking at the raw response from the API rather than the UI.
