Hi, it looks like you’re using some sort of testing framework. Can you try the following snippet outside of a testing scenario and see if you get output?
import com.binance.connector.client.impl.WebsocketClientImpl;
public final class AllTickerStream {
private AllTickerStream() {
public static void main(String[] args) {
WebsocketClientImpl client = new WebsocketClientImpl();
client.allTickerStream(((event) -> {
System.out.println(event);
client.closeAllConnections();
I get the following output which is as expected:
Thank you very much, I have been confused for a long time
