the code work ok in spot,but not work in futures
long unixTime = (long)(DateTime.UtcNow - new DateTime(1970, 1, 1)).TotalMilliseconds;
string na_zakod = "recvWindow=60000&timestamp=" + unixTime;
var input = na_zakod;
var secretKey = project.Variables["sec"].Value;
byte[] secretkeyBytes = Encoding.UTF8.GetBytes(secretKey);
byte[] inputBytes = Encoding.UTF8.GetBytes(input);
var hmac = new HMACSHA256(secretkeyBytes);
byte[] hashValue = hmac.ComputeHash(inputBytes);
string signature = BitConverter.ToString(hashValue).Replace("-", "").ToLower();
var result = ZennoPoster.HttpGet(
	url: "https://api.binance.com/api/v3/account?signature="+ signature+"&"+na_zakod,
    //content: na_zakod,
			   // contentPostingType: "application/x-www-form-urlencoded",
			    proxy: project.GetProxy(),
			    Encoding: "UTF8",
			    respType: InterfacesLibrary.Enums.Http.ResponceType.BodyOnly,
			    Timeout: 30000,
			    Cookies: "",
			    UserAgent: "curl/7.38.0",
			    UseRedirect: false,
			    MaxRedirectCount: 0,
			    AdditionalHeaders:    new String[] {
			        "User-Agent:Mozilla/4.0 (compatible; PHP",
			        "X-MBX-APIKEY:"+project.Variables["key"].Value+"",
			        "Content-Type:application/x-www-form-urlencoded"
work ok in spot,but i change the url to futures it not work,
	url: "https://fapi.binance.com/fapi/v2/account?signature="+ signature+"&"+na_zakod,
			    proxy: "",
			    Encoding: "UTF8",
			    Timeout: 30000,
			    Cookies: "",
			    UseRedirect: false,
Can someone help me see what’s wrong?
Can you show the response? The response will give the hints on why it didn’t work.
THX!
It’s solved. Just put the signature parameter at the end.
