Testnet Symbols
I am looking to test a algorithm on the testnet, but it seems like not all the symbols are available. Is this normal or is there something specific I would need to do to get access to all the available symbols? I am looking for BTCEUR, ETHEUR and others.
This is normal. You can use this endpoint (/api/v3/exchangeInfo) to check for all available symbols.
