Tansfert Between Spot account and earning/stacking
Hi everyone,
I saw that earning account api is not available yet, i would like to know if is it possible to get all transaction from our spot account to this earning/stacking account ?
i didn’t find it on the api, but i’m maybe blind :upside_down_face:
This transfer is currently not supported. You have do it through the UI. These are the supported transfers via api https://binance-docs.github.io/apidocs/spot/en/#user-universal-transfer
only supported transfert are Spot account transfer to C2C account and Futur marging mining account,
Anything about stacking pool even fiat deposit…
In case, i found out that assets in stacking appaers in my accountInfo query result with an LD as prefixe. The amount stacked appear in spot attribute.
