Does anybody know, how to swap the BNFCR to for ex. BNB using an endpoint? Unfortunately my wallet converted to Credit Trade Mode and now it’s impossible to transfer from USD-M Futures to Spot, without a Swap.
Also there is no documentation about in API-Docs or somwhere else I found.
Hi Petar,
thank you, but I need to do this via an API-Endpoint and not within the GUI. In GUI/Webapp there is no Problem to do that, but for convenience, I would like to automate the transfer
Hi, I also need an API-Endpoint or other solution for virtual sub-account swap (Credit Trade Mode on futures). Is there any way to swap on virtual sub-accounts?
Thank you
Tom
I’m also facing the same issue and haven’t found a solution so far. It seems that there’s no option for virtual sub-accounts in the WebUI, and I haven’t come across any relevant endpoints in the Sub-Account API either.
Update on Virtual Sub-Account Swap Solution
The Binance Support team suggested using the following endpoints for converting funds within virtual sub-accounts in Credit Trade Mode:
However, this approach appears to require additional permissions, as per the Binance Convert API docs. In my case, it returns: {"code":-1002,"msg":"You are not authorized to execute this request."}
Workaround:
Since this method is restricted, Support suggested an alternative approach that works:
Use the following endpoint to transfer funds from a virtual sub-account to the master account: POST /sapi/v1/sub-account/futures/internalTransfer
Then, convert the funds within the master account before transferring them back.
This workaround is functional, but it requires additional steps.
