SubscriptionClient Error (Python SDK)
Hi!
I have been playing around with python futures SDK and have got it to work good for calling their restapi, no real issues there. But for my trading i need the user data stream subscription and therefore the sub-client provided by the SDK.
The issue here is that no matter what i do i get the same error. I used the example in the documentation and get this error :
Exception in thread Thread-1:
File “C:\Users\smlma\AppData\Local\Programs\Python\Python39\lib\threading.py”, line 950, in _bootstrap_inner
self.run()
File “C:\Users\smlma\PycharmProjects\BinanceApi\venv\lib\site-packages\binance_futures-1.1.0-py3.9.egg\binance_f\impl\websocketwatchdog.py”, line 42, in run
File “C:\Users\smlma\PycharmProjects\BinanceApi\venv\lib\site-packages\apscheduler-3.7.0-py3.9.egg\apscheduler\schedulers\blocking.py”, line 20, in start
super(BlockingScheduler, self).start(*args, **kwargs)
File “C:\Users\smlma\PycharmProjects\BinanceApi\venv\lib\site-packages\apscheduler-3.7.0-py3.9.egg\apscheduler\schedulers\base.py”, line 150, in start
self.add_executor(self._create_default_executor(), ‘default’)
File “C:\Users\smlma\PycharmProjects\BinanceApi\venv\lib\site-packages\apscheduler-3.7.0-py3.9.egg\apscheduler\schedulers\base.py”, line 763, in create_default_executor
return ThreadPoolExecutor()
File “C:\Users\smlma\PycharmProjects\BinanceApi\venv\lib\site-packages\apscheduler-3.7.0-py3.9.egg\apscheduler\executors\pool.py”, line 50, in init
pool = concurrent.futures.ThreadPoolExecutor(int(max_workers))
File "C:\Users\smlma\AppData\Local\Programs\Python\Python39\lib\concurrent\futures_init
.py", line 49, in getattr
from .thread import ThreadPoolExecutor as te
File “C:\Users\smlma\AppData\Local\Programs\Python\Python39\lib\concurrent\futures\thread.py”, line 37, in
threading._register_atexit(_python_exit)
File “C:\Users\smlma\AppData\Local\Programs\Python\Python39\lib\threading.py”, line 1370, in _register_atexit
raise RuntimeError(“can’t register atexit after shutdown”)
RuntimeError: can’t register atexit after shutdown
I have tried to tweak this myself and the same error appears every time. I am by no means an expert in python programming and i am having trouble finding any decent info about this Threading error.
Are there anyone who have experienced the same error or something similar with the sub-client who are willing to share his thoughts about this one?
Nothing else in my setup ( api_keys etc) is the issue as i have doublechecked everything times and times.
Thanks!
Edit:
the code i am trying to use is any of the example codes provided in the docs, for example
import logging
from binance_f import SubscriptionClient
from binance_f.constant.test import *
from binance_f.model import *
from binance_f.exception.binanceapiexception import BinanceApiException
from binance_f.base.printobject import *
logger = logging.getLogger(“binance-futures”)
logger.setLevel(level=logging.INFO)
handler = logging.StreamHandler()
handler.setFormatter(logging.Formatter(’%(asctime)s - %(name)s - %(levelname)s - %(message)s’))
logger.addHandler(handler)
sub_client = SubscriptionClient(api_key=g_api_key, secret_key=g_secret_key)
def callback(data_type: ‘SubscribeMessageType’, event: ‘any’):
if data_type == SubscribeMessageType.RESPONSE:
print("Event ID: ", event)
elif data_type == SubscribeMessageType.PAYLOAD:
PrintBasic.print_obj(event)
sub_client.unsubscribe_all()
else:
print(“Unknown Data:”)
print()
def error(e: ‘BinanceApiException’):
print(e.error_code + e.error_message)
sub_client.subscribe_mark_price_event(“btcusdt”, callback, error)
I get the error mentioned above, then this one tick:
Event ID: 1614076217779
closeTime:1614076224735
count:371926
eventTime:1614076224738
eventType:24hrTicker
firstId:53275300
high:2222.0
json_parse:<function SymbolTickerEvent.json_parse at 0x000002B7C1B9E5E0>
lastId:53647842
lastPrice:1479.52
lastQty:6.208
low:20.0
open:1819.57
openTime:1613989800000
priceChange:-340.05
priceChangePercent:-18.688
symbol:ETHUSDT
totalTradedBaseAssetVolume:720890.177
totalTradedQuoteAssetVolume:1187451208.85
weightedAvgPrice:1647.2
2021-02-23 11:30:22,968 - binance-futures - ERROR - [Sub][1] Closing normally
2021-02-23 11:30:22,968 - binance-futures - INFO - [Sub][1] Connection event loop down
The same occurs with every subscription function i have tried, modifying the urls and recieve_limit: is_auto_connect=True, receive_limit_ms=3600000, url=“wss://fstream.binance.com”)
Post your code (only the ones that triggers the error) and don’t leak your api key/secret if it’s for prod.
This error doesn’t affect the listening of events for the user stream. If you see an event id printed after the traceback, then it’s fine.
Yes i do get one event id, but then this 10 seconds after.
Comment above line out and try again
