start_multiplex_socket
Does anyone know what is the latest version of “start_multiplex_socket()” function on BinanceSocketManager ?
which library are you referring?
Binance.streams
I mean a library, not a function. Is there any github repo of the library you are using?
Here are the ones I use. Binance.Stream was mentioned on Github as well as Binance.client
