Stablecoin Conversion via API
How can you create a stablecoin conversion via a REST API call? If this is not yet functional, is it on the roadmap? If so, when is expected implementation?
stablecoin conversion is not available yet from API. not sure about the roadmap.
Thanks dino. Any Binance folks open to sharing if this is on the roadmap / when? Seems odd that a significant UI capability exists without support for developers to use…
