Some sapi funtions from p2p api for merchants don't work
Hi. I’m merchant. Support gave me api for p2p and i try to write bot for p2p trading. But some functions works, some not
This is work:
POST /sapi/v1/c2c/ads/getDetailByNo
Code below
import hmac
import time
import hashlib
import requests
from urllib.parse import urlencode
KEY = ""
SECRET = ""
BASE_URL = "https://api.binance.com"
def hashing(query_string):
    return hmac.new(
        SECRET.encode("utf-8"), query_string.encode("utf-8"), hashlib.sha256
    ).hexdigest()
def get_timestamp():
    return int(time.time() * 1000)
def dispatch_request(http_method):
    session = requests.Session()
    session.headers.update(
        {"Content-Type": "application/json;charset=utf-8", "X-MBX-APIKEY": KEY}
    return {
        "GET": session.get,
        "DELETE": session.delete,
        "PUT": session.put,
        "POST": session.post,
    }.get(http_method, "GET")
# used for sending request requires the signature
def send_signed_request(http_method, url_path, payload={}):
    query_string = urlencode(payload, True)
    if query_string:
        query_string = "{}&timestamp={}".format(query_string, get_timestamp())
    else:
        query_string = "timestamp={}".format(get_timestamp())
    url = (
        BASE_URL + url_path + "?" + query_string + "&signature=" + hashing(query_string)
    print("{} {}".format(http_method, url))
    params = {"url": url, "params": {}}
    response = dispatch_request(http_method)(**params)
    return response.json()
# used for sending public data request
def send_public_request(url_path, payload={}):
    url = BASE_URL + url_path
    if query_string:
        url = url + "?" + query_string
    print("{}".format(url))
    response = dispatch_request("GET")(url=url)
params = {
    "adsNo":"11378191646449455104"
response = send_signed_request("POST", "/sapi/v1/c2c/ads/getDetailByNo", params)
print(response)
But when i try for example to change status of ad. I got an error
POST /sapi/v1/c2c/ads/updateStatus
code below
import hmac
import time
import hashlib
import requests
KEY = ""
SECRET = ""
    return hmac.new(
    ).hexdigest()
    return {
        "GET": session.get,
        "PUT": session.put,
    if query_string:
    else:
    url = (
    if query_string:
params = {
    "advNos": ["11378191646449455104"],
    "advStatus": 0
response = send_signed_request("POST", "/sapi/v1/c2c/ads/updateStatus", params)
print(response)
I got an error
{'code': -1000, 'msg': 'An unknown error occurred while processing the request.'}
Please help. What am I doing wrong?
Looks like you are sending the parameters in your url and also in the body. Remove the parameters from the url and try again. Also try to urlencode the params before sending.
Karagiozis Karagiozis how did you solve this problem, i’m facing similar issue, the solution suggested is not working for me
Someone solve this problem for sapi c2c? This error show on every POST request where parameters must be in the body… Binance support doesn’t respond nothing about this issue…
Please help, how did you solve this problem?
