I apologize if this has been answered before but I didn’t found an answer to my question.
I want to have my API in read-only mode and I just want to get information about the amount of coins I have in my account, so x BTC, y ETH, etc.
And then I want to get the current value of those coins.
I want to do this with Java.
Can someone share some example/tutorial on how to do this?
Thank you.
Hello, we don’t have examples for that, but you could find a library suitable for you, for example: https://github.com/binance-exchange/binance-java-api
The api endpoints to get the “amount of coins I have in my account” and “current value of those coins” is in the API document, to facilitate, pasting here their respective links:
https://binance-docs.github.io/apidocs/spot/en/#account-information-user_data
https://binance-docs.github.io/apidocs/spot/en/#symbol-price-ticker
Thanks @aisling.
I think my doubts were about those libraries that I see around. I was expecting to just need the binance API. That said, is it safe to use these libraries?
