Hi!
I couldn’t find this explicitly mentioned in the documentation, although I believe I may have come across a reference to it somewhere. I’m curious if, in the case of a difference depth stream combined connection:
Are the instruments always guaranteed to arrive in the same order with each 100ms interval, 100% of the time?
The order I’ve observed is different from both the order of my combined link and alphabetical order:
My link:
wss://stream.binance.com:443/stream?streams=btcusdt@depth@100ms/ethusdt@depth@100ms/bnbusdt@depth@100ms/solusdt@depth@100ms/xrpusdt@depth@100ms/dotusdt@depth@100ms
and the sequence of my orders:
