Sending orders/updates with FIX protocol
Friends,
I would like to use the FIX protocol to send and update my orders (for market making) instead of using the REST API.
Do you know where is the documentation?
Thanks.
Pedro.
FIX is not available on Binance. It will be in the API document if it’s supported in future.
