Schema or Java sdk
Does Binance provide any schema-related data for JSON responses of Binance APIs or do you have any Java SDKs/dependencies that we can use in our code to convert the JSON responses to Java POJOs?
Please share any related data to this.
Thanks in advance.
We may need to create your own Java class based on the json data format. We may add it to the java connector in a later release, but no ETA.
thank you.
