the endpoint “api/v3/userDataStream” working fine. However,
“sapi/v1/userDataStream” is not found. Am I missing something in the docus?
Which environment (production or testnet) and method did you try? It has POST, PUT and DELETE.
production I suppose (I can fire trades) where to check it? and I am using POST. Anyways, using PUT didn’t change anything.
The API looks fine. Please check if you attach the proper X-MBX-APIKEY, thanks.
