RSRUSDT futures can not cancel limit order
Hi folks,
I have an odd issue. I am trying to trade RSRUSDT future but getting an error when trying to cancel the limit order. Here is the error:
{“code”:-2011,“msg”:“Unknown order sent.”}
Also I noticed that all other coins I trade have 9 digit order ids whereas RSRUSDT has 16 digit ids. Not sure if this is related to the issue I am having.
Any info will be helpful.
Thanks.
If you’re using JS, please use client order id to cancel your order; The order id of this trading pair has exceeded the max_safe_integer of JS
