Reinforce positions
Is it possible to reinforce my position by buying or selling same symbol with different leverage ?
Example : I have 10 ETH already positioned. LONG . And with leverage =5
I want buy others 20 ETHs - LONG with leverage = 15
It’s possible ?
After , How I know the ENTRY PRICE and others data of my secondary position ?
Tks
It’s possible to adjust leverage and place another order to adjust current position.
Thank you Dino !
Only one POSITION appear at UI , right ?
And how can I see data of these two or more positions ?
Qtty is de sum of the several positions , right ?
Can I see the entry data of both positions ?
The new or more recent leverage is the used to calculate PNL ?
Wich is the brother API to see these data ?
Tks
