Hi every one,
I have no problems to get histocial data and real-time data.
Now I would like to calculate indicators using historical data in real time, as twap and moving average.
I’m wondering if I need to stock some historical data in a variable, with a loop to add the last value (depend on the timeframe), Then create a method which calculation and display.
Does someone have a good way or advice to do that?
Thanks!
Ben
Not as suggestion, but maybe some popular libraries like ta-lib or tulip might be helpful for you to get the indicators values.
Hi aisling
I already check, and yes, ta-lib looks pretty good to fetch some indicators’ data.
But twap is not available.
Maybe I’m on a good way, for the moment, I put my streaming data in lists, I have a maximum value in this list, and each loop I retrieved one to leave the place at another and calculate the indicators again with the precedent value and the new one.
Thanks for your answer
