hi,
can you please tell me where is the binance server deployed? We want to rent a cloud server nearby, so that the network data transmission can be faster.
Sorry, we can’t help with this question. Use the server that’s best suitable for you.
Hi, could you pls share, where at the end you decided deploy your backend? Perhaps you made some tests and found a best location?
